I believe that 4ft^3 enclosure from the DIYSoundGroup is designed for the HT-18, so if that's the case it should work fine. You could increase the perceived volume by adding 1lb of loose-fill stuffing per cubic foot, which probably isn't a bad idea anyway (reduces the backwave off the driver).
