1 - 5 of 5 Posts
My apologies if this has already been requested or has been implemented in beta.
I would like to be able to make the crosshairs on a graph disappear entirely. Using 5.0, once I click on a graph the crosshairs appear and the only way I can sort-of make them disappear is to push them into a corner, but they're not really gone.
Thank you.
No plans for that, but if you are capturing an image of a graph using the Capture button the cursor is not shown unless you select it in the Capture options.
Hi.I want to ask for a small supplement.
To measurement mode the display shows not only the level of the current signal and also the current frequency to be able to assess changes in the hearing.
If you open the REW signal generator while measuring you will see the sweep frequency displayed there, but the best indication of how level changes with frequency is the frequency response plot.
1 - 5 of 5 Posts
