1 - 10 of 10 Posts
I'm in the process of building a theater in my basement - which was previously unfinished area. Did a dual wall - with a separated joist ceiling for the theater (not connected to the existing ceiling). 2 layers of 5/8 Rock with Green Glue walls and ceiling.
I"m in the process of doing electrical/data and video cabling. Have a 2 inch interduct in for the projector in case i need to add/change something there in the future.
I'm putting in AudioQuest 14/4 wire (14Gauge/4 conductor) for each of the speaker locations. I had also planned additionally to run 1 1/2 inch Interduct to the front of the room - the surround speaker locations and rear speaker locations - only for future use (leaving it empty at this point). Figuring at some point in time I - or someone else - would want/need to replace that speaker wire. It's one of those - "can't imagine needing it, but i'll regret not doing it" sort of things.
Am i crazy? It is definitely going to be a hassle just cuz of the additional wall boxes for terminating the interduct and all.
For those of you that have done it... i have questions...
1. Glad you ran the interduct to the speaker locations?
2. How did u terminate the interduct? I am thinking a fitting into the back or top of a single gang box, putty pad the back of the box - and jam the box full of puddy or something to minimize sound transmission into the duct...
What is interduct? Is this some sort of ducting that you make and run your wires through or is it something you buy? I have only heard of using PVC for running wires in the wall or running them without any enclosure.
Yes - it is corrugated - usually made of HDPE (plastic) - so it's flexible and is run in walls and ceilings to give you a place to pull cable POST construction. Much easier and cheaper to run than rigid PVC. It's what's used in commercial buildings - also used in data centers for running more sensitive cables like fiber optic runs. Also - When using a large diameter PVC for underground use - mutliple Interducts are often put through it - to minimize the intercable friction when pulling cables at a later date.
For the purposes of my question - you could think of it as running PVC in the walls for the speaker runs... worth it or not?
Definitely do the conduit. I've seen more than once having a speaker wire shorted out by a careless screw during the drywall process. I ran 4" to my PJ - you never know what kind of odd new connector they're going to come up with. 2" can get a little tight when you figure 2 HDMI, Cat 5/6, maybe a composite and/or component for gaming systems/control screens, etc.
Bryan
I would definitely use interduct if you have the opportunity and the cost isn't too high. That way you will always have an accessible path.
All my conduit does a 90 degree turn from the ceiling down to the wall, then stops. I have a string going all the way through the conduit and down the wall to the outlet/hole/whatever. I don't see the need for conduit going all the way down the wall and to a outlet, especially if you have double stud walls with a cavity between where cables can run up and down easily. Sound transmission shouldn't be a problem that way as long as your outlet box is sealed, because the conduit will be behind the drywall.
1 - 10 of 10 Posts
