1 - 9 of 9 Posts
can the Denon 3808ci be used with the denon 4300 to make it 11.2 thanks
or is there any other denon amp that can be used with the 4300 to make it 11.2
Super Moderator
You didn’t indicate which of the three Denon and Marantz units you intend to use as the primary receiver, so I can only guess that you’re using the 4300 since it has dual subwoofer outputs. You can send the pre-amp outputs from the 4300 to a pair of inputs on the secondary receiver. Set the secondary unit for “bypass” or “stereo” and use the front-channel speaker connections.
1 - 9 of 9 Posts
