1 - 15 of 15 Posts
a person has told me that with rew you/he/she is possible to record the sweep with the filter inserted in an average-player (foobar 2000)
it takes a card audio that manages an inside routing
how could you/he/she be explained?
I apologize me for the difficult translation italiano/english
annacamilla.
I believe you have to measure your room with REW and create a set of filters that you like, and then use FILE / Export filters Impulse response as WAV and then convert the WAV to a format the convolver software in the HTPC can read. Read over that thread I mentioned above.
we see if we can understand better there
I would like to understand come to measure of it is able of they are governed here is sweep an answer corrected by the convolver
comes to you/he/she has made this person
green = sweep rew
red = sweep inserted convolver...... as you/he/she has been able to measure the sweep with the inserted convolver?
annacamilla.
Hello Annacamilla,
At present the only way to measure the response after applying correction is to use an equaliser or an external application, such as a convolver, to apply the filters. I do plan to add the ability to produce a sweep which has filtering applied to it, so that you can measure what the filters would achieve. I also plan to allow the filtering to be applied to the measured signals within REW so that it can give an accurate prediction of the corrected response including waterfall. Those features may be available at the end of this year.
Hi John - did this ever get added? I asked basically the same question yesterday (http://www.hometheatershack.com/for...suring-software-eqed-response.html#post525549), before running across this thread.
1 - 15 of 15 Posts
