1 - 3 of 3 Posts
Unlike the MacIntosh version (MEN-220) of the Lyngdorf RP-1 (or the preamp version DPA-1), the voicing software does not let you create new voicings.
However, after taking a look at the McIntosh software, and the file structure of the Lyngdorf voicing files, after a lot of effort I created an excel macro sheet to be able to create your own voicings.
I've zipped it and it should be attached to this post.
You can create 6 different filters (stereo linked).
Useful for when the RoomPerfect is not so perfect and you want to add additional PEQ based on your REW measurements or whatever!
Doug
Hi Doug,
I would like to thank you very much because your voicing tool is the holy grail for me because it allows me to eliminate some room nodes in my system. I have a small issue when switching to the custom voicing. Sometimes a loud short hum/distorted noise is comming out of my speakers when doing that. I don't have peaks in my custom voicing. Only parametric EQ dips, some -12db. Can it be that there is a small fault in the .voi files your tool creates? I am using TDAI2200 in stead of the DPA-1 but assume they work the same in this regard.
Alex
PS. two years after your original post, I hope you are still active on this forum
1 - 3 of 3 Posts
