I need to change the STK 392-110`s in my RPTV. While doing my backround research about this i see that improved STK`s are the advised answer, however it appears that the Hitachi kits come with resistors of a different value than those which were originally used. As mine is not a Hitachi brand i understand that these resistors are not applicable to my set, however as the use of either a 392-150. or a 394-160 will change the power consumption of the overall circuit, I would like to know if i need other than original ohm rated resistors? If that is true how would I determine the value of them?
Thank You
Thank You
