1 - 2 of 2 Posts
G
I'm looking at the service manual, and the dimensions of the grid. Are they in mm?
Also, What does the control ( vertical linearity ) VLIN do?
Plain ole user
If I recall correctly they give some values in mm and some in the number of grid squares.
Vertical Linearity and other adjustments are described here:
http://www.hometheatershack.com/for...based-rptv-convergence-repairs.html#post47149
VLIN will make the top and bottom size change in opposition. In other words, you will make one larger while the other is made smaller. You adjust it so that the size of the blocks at the top and bottom are equal.
1 - 2 of 2 Posts
