1 - 3 of 3 Posts
Well finally making head way but have just one more question about the toshiba projection set. This board is badily damaged and a semiconductor has toasted the board under itself. It appears the trace is intact! Take a look and tell me if its still viable for this application. All comments are welcomed and appreciated
Plain ole user
If the traces are intact then claen them up, tin them with a layer of solder and you will be fine. If they are not you need to build connections, either with new trace material or a small lead or wire.
Thanks dude thats what I did. Really just wanted to be sure if you check my othwr thread maybe you can offer some insight on that issue. Thanks again for you time and interest.
1 - 3 of 3 Posts
