1 - 3 of 3 Posts
i HAVE THE 50 TOSHIBA AND AM HAVING PROBLEMS WITH THE HYPER MODULE. I WOULD LIKE TO ORDER THE ELECTROLYTICS AND HAVE THEM ON HAND WHEN i REMOVE THE MODULE. DOES ANY ONE HAVE A GOOD PART NUMBER AND VENDOR I CAN ORDER FROM OR WHAT SIZE (PHYSICAL) I SHOULD ORDER. I HAVE THE VALUES AND AM CONSIDERING REPLACING ALL ON BOARD CAPS. THANKS IN ADVANCE FOR ANY ASSISTANCE.
· Plain ole user
There are vendor listings in the pull down at the top of every forum page, as well as in the service and support forum in several places. My recommendations would be Acme, B&D, DigiKey, or Mouser for caps. The values are going to vary for each set, but most of the hyper modules at least need the 10uF and 22uF polar electrolytics replaced. Most need more, but you have to check them to know. If you don't have an ESR meter, I suggest just changing the 2 values above and if that does not work change them all.
Also, please read the forum rules. Posting in all caps is considered inapproriate.
1 - 3 of 3 Posts
