1 - 2 of 2 Posts
Is there a reason not to use a 3 way tower as a sub? The tower has a built in sub, with dual 10" drivers. The bass response is better than most subs available today. It's a VMPS Mini Tower IIA.
It would be cut off at 150 hz and above.
Will it blow up?
HTS Moderator , Reviewer
Almost without exception, where a speaker sounds best and where a sub sounds best will be different. That's why you rarely find speakers with 'subwoofers' built in, because it's too much of a compromise. If they're separate products you can place each where it will perform the best.
1 - 2 of 2 Posts
