1 - 4 of 4 Posts
Hi i have transferred REW over to a XP laptop, two problems i am experiencing.
1. With REW only the computer runs very slow
2. When i run the sweeps there is a noise come through the speakers when running on power, ok when running on battery but cannot hold the charge what so ever.
Thanks in advance
the current version of REW certainly works fine on XP. If the PC is running slow then you could consider installing linux on there instead or going for a fresh XP install.
The laptop runs fine on other programs and in general runs very well, except REW.
1. I have noticed it is running Service Pack 2, would this make a difference?
2. Also when i open a Mdat file that i have measured a few days ago i get a blank screen (exactly the same as opening a new file) and have use "Open" then click the file to be opened.
Thanks in advance
1 - 4 of 4 Posts
