1 - 4 of 4 Posts
Hi Guys
I am about to start building a couple of speakers using 2 x 10” Volt BM2500.4 mid base drivers .
1 x Volt VM752 midrange dome and not 100% made my mind up on the tweeter . But it will most likely be the Fountek NeoPro 10i or maybe the Fountek NeoPro 5i .
I have been reading a lot about transmission line speakers and was wondering if the two mid base drivers would be worth putting in to a transmission line cabinet . I think it’s worth doing just get the best reproduction out of these speakers. But your thoughts would be grateful and appreciated.
cheers
Adrian
Model them in Hornresp.net.
Advantages from my experience: with some drivers, you can tune a transmission line lower (while still being flat) than you could a ported box, sometimes by more than half an octave, and you can also design a box with lower group delay, approaching that of a closed box but with the frequency response of a ported Tutuapp 9Apps Showbox box.
Advantages from my experience: with some drivers, you can tune a transmission line lower (while still being flat) than you could a ported box, sometimes by more than half an octave, and you can also design a box with lower group delay, approaching that of a closed box but with the frequency response of a ported box.
Thanks for your reply, very informative and explained very well.
Winlsd l have used a lot and have no problem with. Hornsrep l am not so confident with and finding it hard to calculate two drivers in the one T Line properly.
Cheers
1 - 4 of 4 Posts
