The shortest way to answer that question Mike is that I have used every type of contact cement you have named and a couple that John has mentioned. I never use the stuff on wood veneer. It fails as I mentioned.
Longer answer is that on commercial work that will be replaced before failure yes it gets used from time to time as it is a much faster method of applying flat veneer or curved veneers to panels. But as for longevity there are better methods. Iron on yellow glue method is one of the easiest and most forgiving. If John had used veneer tape to setup his book match and border he probably could have used the iron on method. You have to tape both sides when you need to play with setup a bit more than usual. Veneer tape is very thin and not a problem when under the veneer.
Mark
Mark
