would there be a difference if i used the 10" as apposed to the 12" i have very limited space... it almost seems not worth going with the 10" kit as the price on the trio 12 is not much more.
Everything Mike says. Louder will not be to noticeable. Only about 3 to 6 db depending on the frequency. But the greater evenly loaded listening room will be very noticable. You will have half the dead zones in your room. Areas where there is no real bass sensation due to reflections calceling it out. Driving the room from another point will help to get you a much more even response.
So is this a long slow drive or a quick shot across the street type drive?
Hehe!
Mark
Hey I can relate. I'm still trying to figure out how to properly measure the horn loaded monster that i built. Even output is not the problem there. structural damage is the problem!
Mark
101 - 109 of 109 Posts
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
