I currently have an 8" ORB Audio sub in my home theater. My living room is about 20' X 12' and opens up to the kitchen that is about a 1/3 of the size of the living room. I currently have 2 10" AA arsenals that are sitting in my garage. I want a bigger sub stage. Something that will extend into the 20hz range. I would like to build an enclosure geared toward my home theater. FYI, I have some building skills, so I can build an enclosure for any box design. I have between 4.5-5.25cu.ft to work with on each sub in my living room. Here are the parameters of the Ascendant Audio Arsenal 10"
Driver Specs:
Znom
ual 4 ohms
BL : 19
Re Dual 3.5 ohms
Sd: 330 cm2
Fs 29 Hz
Mms 150 g
Vas 31.2 L
Xmax 20.5 mm
Qms 4.01
Spl 83 dB 1W/1M
Qes .59
Qts .515
Rms 750W
Le 1.8 mH
-Bob
Driver Specs:
Znom
BL : 19
Re Dual 3.5 ohms
Sd: 330 cm2
Fs 29 Hz
Mms 150 g
Vas 31.2 L
Xmax 20.5 mm
Qms 4.01
Spl 83 dB 1W/1M
Qes .59
Qts .515
Rms 750W
Le 1.8 mH
-Bob
