1 - 4 of 4 Posts
I think you got your answer in the other thread.
A tripod mounted projector stand might work for you, but I personally consider that tacky when a projector can be almost completely hidden in a ceiling mount or on a table below eye level, both of which are not on the screen axis. No disrespect to the tripod mounting, but the flexibility lens shift allows, is very valuable in my opinion.
1 - 4 of 4 Posts
