1 - 4 of 4 Posts
I have everything swithched properly according to all the info ani I hit send filters to eq, it appears to be loading the FBQ. But when its finished the FBQ does not show any filters. Whats up?
Thanks, Rick.
Does the FBQ Midi LED flicker when filters are being downloaded? If not the Midi in/out connections might be the wrong way around.
If you set up a manual filter on the FBQ does it get overwritten? Are you selecting the measurement from the list which has the filters you want to send?
The midi lights do not flicker. I bought a Yamaha UX16 midi interface and connected like the instruction said, in to in out to out.
No filters get overwritten
After calculating the filter settings I click on the Equaliser tab and hit send filter settings. The progam shows the its loading.
Thanks, Rick
I just reread the Midi interface instructions, I had the in and out backwards, everything works now.
Thanks again John.
Rick.
1 - 4 of 4 Posts
