You might want to consult your manual or do some further testing. We’ve had people here who had this problem and eventually discovered that their receiver’s bass management only worked for digital sources and signals.And if the XR55 is setting the fronts to SMALL, and crossing them over at 80Hz, how in the world are the PBS' still playing at the level they are, so far down in the response? Is that another room anomaly?
That’s fairly optimistic extension for a speaker with such small woofers, unless they’re unusually inefficient. And yes, the room makes a difference. Small rooms reinforce bass; large rooms “soak” it up. Keep in mind that the speakers “see” all those areas open to your family room.Still, the ELT's are supposed to be +/-3dB down to mid-60's or so. That's why I'm thinking something about this room is just sucking down that part of the response...
Well, I sure hope not. The Panny's manual is pretty bad, and not very specific about the crossover, but I can test that theory with sweeps using different crossovers.You might want to consult your manual or do some further testing. We’ve had people here who had this problem and eventually discovered that their receiver’s bass management only worked for digital sources and signals.
Good idea, and you are probably right about that, since the left speaker has two-wall reinforcement. And while I'm at it, I guess I should look at each PBS separately. This could get complicated.you might also want to take some readings of your L/R separately. I expect that the left speaker has much more pronounced bass than the right one.
That would be me! :hissyfit:You might want to consult your manual or do some further testing. We’ve had people here who had this problem and eventually discovered that their receiver’s bass management only worked for digital sources and signals.
I've not tried the sub in the right front corner. When I originally selected the left rear corner, I had placed the sub on the couch, and then used my meter to check levels at several possible sub locations. The right front corner was very low level--pretty much like no corner at all.Dave - have you tried your sub in the opposite corner up by the right speaker? Also, do you have enough slake in the wire to the right main to try moving it closer to the listening position? Maybe you can measure and find the better location, and when not in use, move it back against the wall like in your layout.
LOL. Yeah, traps would probably help. My wife is a sweetheart, she really is. And she had no problems with the speakers and the sub. But I showed here some pictures of bass traps and such, and well, she kinda drew the line in front of that proposal.Looking at the response from your mains, it looks to me like you would greatly benefit from some broadband traps. It doesn't look like there are many places to put such beasts (not to mention WAF).
You should try getting a REW graph in that location just for a comparison.I've not tried the sub in the right front corner. When I originally selected the left rear corner, I had placed the sub on the couch, and then used my meter to check levels at several possible sub locations. The right front corner was very low level--pretty much like no corner at all.
I meant to just place the speaker there during listening times and move it back against the wall when not in use.The room is hard to work with. The right front speaker really can't come closer into the room. Yes, there's slack in the wire, but pulling it forward puts it into the main walking path from the kitchen area to the stairs going up. The kids are bound to hit it.
