I have a Toshiba 52HM84 and the TV is making a buzzing sound coming from the power supply for the lamp. Can you help me out why?
I always hear a popping/craking noise on my TV. I tought it was the heat inside the TV that caused the plastic to expand or contract ..... Do you think this can be the cause???? (My TV is a Samsung HLS 6767 DLP) .... When I was looking for a reason to this noise, I found that you can loose the screws that attach the case of the Tv and it will help ... I did it and the noise is less frequent than before but still make it from time to time .....:huh: :huh:When high voltage leaks from a second anode, it can be dangerous and violent. What you were likely seeing was a high level of static electricity building up around the anode lead. There is a big difference. Older sets with poorer grounding paths tended to have more of this than more modern sets. Regardless, over the thirty years that I have been repairing TVs, manufacturers and servicers take great care to be sure that HV does not "leak" from anode leads. When it does it is rare. The roughly 30KV in most sets will, however, cause significant static electricity and dissipating it can cause a crackling sound or ticking sound. Occasionally, a pop or a crack will be heard if it build up too much before discharging.
