1 - 2 of 2 Posts
What is a solid mount for a 65-75 inch LED ?
I see a couple on Amazon for around 25 bucks that have rave reviews but it looks like they tilt down a bit ? Do you want the LED to tilt down I would think it needs to be completely vertical and parallel with the floor. Anything under 100 bucks is fair to spend. I do not need this to articulate up down in or out...
I can't speak for $25 mounts, except that I hear articulating styles can be unstable for that price.
You would want the display to tilt down if it were mounted at a high viewing angle, or to avoid reflections.
1 - 2 of 2 Posts
