1 - 2 of 2 Posts
I have a Marantz NR1607 AVR and I wonder if anyone knows if I can get two two outputs from one source. I would like to stream from one into my hearing aids and the other would be for my wife to hear the same sound.
I have TV Streamer 2 from Resound with mini audio input, Optical (Toslink) and Coaxial input. Those I connect by blutooth with my hearing aids. Then is there another way that will output sound to the surround speakers?
I have an LG UH8500 Smart TV with HDMI, optical digital out and Component and Composite in. I am using HDMI ARC to the TV.
Super Moderator
”Those?” The hearing aids require the use of all three? Why?
I wonder if anyone knows if I can get two outputs from one source.
It will logically require the source to have two outputs.
That unit has no audio outputs. Which makes sense because it is not a “source.” It merely accepts an input from a “source.”
Best as I can tell, the “source” is the TV? You should be able to use its coax output for your Resound, but as far as I know, the HDMI ARC will only work to get audio to the Marantz if the both the TV and Marantz support ARC.
Alternately, if the TV has a headphone jack you could use that for the Resound and the TV's optical out to the Marantz.
1 - 2 of 2 Posts
