80 is a pretty good number to start with. You can adjust to taste, but you'll probably find it works good. I have experience with the sb2k. It is an absolutely spectacular sub. As long as the room isn't too big, in which case it just doesn't have enough output. It is smooth and articulate, and sounds great. Are you using it with the sb1k?
Sent from my iPhone using Tapatalk
