1 - 10 of 10 Posts
I was building a garage onto my house when the contractor said that for not that much more we can put an bonus room over the garage. So i said Wooohoo my home theaters here!!. Its not a extra large room 25 X 29 But i had it sprayed with foam insultation to sound proof it and added a bar in the back.. Heres a couple of pic's Wall's are a lil bare I need to find a good movie poster supplier and put some on the wall...
Thes walls finished waiting to put the floor in...
light down
Stairway to theater
Floors in
Bar in back
Daughter 's already taken control
Is that a 4:3 screen?
Might want to lower it and go 16:9, as it seems a bit high anyway. Think how much better that Monsters VS Aliens clip would be if it were 3' wider.
You'll also get a better picture if you paint that ceiling black (or dark).
What made you decide to put down wood instead of carpet? You should at least put down some big throw rugs.
Are you planning on upgrading your speakers? You might want to at least mount those fronts on the wall or use stands. Do you have sides? Rears?
Without that bar in the back, you could easily add a riser and two rows of seating too.
Discussion Starter #5
Thanks Spartan, It's kinda 16:9 screen Just not exactly .. The picture are not updated as I Have put in area rugs , Speaker stands, I do have 5.1 others are mounted in the back.. I still have about 3 feet in the back till I get to the bar so I was thinking of putting another tier with a lil smaller seats. I put wood because it sounded a little better and goes with the room décor.. I also built a bathroom in the back opposite the bar. and if you look behind the bar there a fridge built into the wall... Thanks for all the ideas. Ill post the updated pictures tomorrow.. Still learning so all the help is really appreciated
Discussion Starter #7
No, its a bonus room above the garage... It comming together pretty good .. Ill post new pics this weekend .. I have added a small bathrom in the back ( Dont want to keep running up and down the stairs when ya gotta well You know :) . Finally finished all the trim and paint so its looking better. Still need to come up with an idea for the walls tho, Still to bare... Was thinking of doin a whole Drive-In look to it with the ceiling painted with clouds and stars , and cars parked in the back facing the screen with Leds for the cars headlights...
1 - 10 of 10 Posts
