1 - 5 of 5 Posts
hi my question is if you have all of your sources set to native resolution should you have the UMC 1 set to pass trough.
THANKS HOTRIZE
hello Hotrize,
I am new here but I've had my UMC for 2 years now. Yes it should be set to passthrough if you do not want to upscale. The video processing on the UMC is not the greatest so I wouldn't upscale anyway.
Bobby
I agree regarding the video processing. I prefer to leave mine set to passthrough since all my sources can output at native resolution.
I also use pass through, but I have had it on "Auto." My cable is limited to 1080i, so I tried the upscaling. It worked quite well, but for Blu Ray and other "true" HD (1080p for example) sources I'd use pass through.
1 - 5 of 5 Posts
