1 - 3 of 3 Posts
I have a two-way loudspeaker system in which I do not understand the THD
measurements I obtain with REW. The woofer THD measures like this (first jpg) WR unfiltered.jpg
before the crossover filtering (low pass LR2, miniDSP):
Then after the low pass LR2 filter it looks like this (2nd jpg), with lots of
The THD of the two units combined (3rd jpg; LP and HP LR2 with miniDSP) looks like
How can it be that the "distortion" above 1.5kHz which was so obvious in the
woofer trace disappears in the combined unit? I think there must be something
basic about FFT which I do not understand. I couldn't find the answer in the REW
Help PDF.
It won't be distortion, it will be noise. V5.19 has an option to mask results that are in the noise floor, more info on distortion and interpretation here.
Thank you very much. I was only looking in the 5.18 version of the help. I have downloaded 5.19 and will study this now, which may answer another question.
1 - 3 of 3 Posts
