I have just upgraded my front towers from the Energy C-500 to Aperion VGT. The system setup I have now is:
Onkyo 709
Rotel 985 MKii
Aperion VGT
The problem that I'm having is that after upgrading to the Aperions I can now hear an imaging issue. When playing 2 channel music the vocals are shifted to the left speaker. I switched everything but it did not change until I swapped the interconnects.
I have the single Left and Right RCA pre-amp out from the Onkyo connected to a single RCA to dual RCA cables so that I can connect the same signal to 2 channels on the Rotel and then bi-amp the towers.
So knowing that the issue with the imaging is related to the interconnects I have, my question what kind of interconnects are going to allow me this 1 channel split into 2 channel ability?
What is the best way to split one channel to 2 channels? An Adapter and single cables or cables that are made already split?
Could I just use subwoofer cables? I have found some that are split here. If these will work fine then these are what I'd prefer to get since I have dealt with this company before and like their products.
I understand that Monoprice interconnects are an acceptable option but they do not have a 1 to 2 split cable so I would have to use an adapter.
Please, any information and suggestions are welcome. Thanks.
Onkyo 709
Rotel 985 MKii
Aperion VGT
