Hey all,
Just wanted to update you all on my center channel build.
For reference, it's a 3 way design using Dayton RS 8" woofers, HiVi B3N mids, and a BG Neo3PDR tweeter with an open back.
Crossover points are currently 500 Hz (2nd L-R), and 3kHz (4th L-R) on a 12" tall baffle with wings of 4" on top and 6" on bottom. MTM section is vertical D'appolito configuration flanked by the woofers (sideways speaker).
It's been in my system a while now and honestly, I like the sound for dialog only. It is a tad resonant, due mostly to a peak-null-peak in the high bass, low mid region. However, for any sort of music, the weaknesses show. It always sounds like it is holding something back and upper vocals seem to alternate between damped and shrill.
I liken this to the bad baffle design. I am a firm believer that this is the trade of all open baffle designs: what is a good baffle for bass is awful for mids and vice versa. The tweeter seems unphased by the baffle design, as it is pretty flat baffle response from 4k on up.
What I seem to be hearing is a peak right before the woofer hands off to the mids, then the mids have some alternating peak-null-peak throughout their region. If a note hits on a peak, it sounds shrill, in a null it sounds dead.
So, this got me thinking, what if I had two baffles, one for the bass section and one for the MTM. Make the MTM baffle as narrow as possible to eliminate the sine-wave respnose effect of the large baffle, and have a large baffle for the woofs. Essentially, it becomes a sort of "dog bone" configuration for the mains, although in a center, this would look considerably weirder (with the MTM section vertical).
So I have a test baffle to try this out, but haven't finished cutting it out or wiring anything up yet. I feel good about this approach, though.
So pics to come once I get this thing in the test phase.
Anthony
Anthony
