Ok i pulled the board out. I checked all the resistors with my ohm meter all seemed to checked out fine. I then proceeded to check the convergence chips with the meter, there is a difference between the two. Not sure what they should read on the ohm meter but checking the pins on one the meter went up and stayed checking the second. In the same manner as the first the meter went up then faded away. Now correct me if i am wrong but thaat shouldnt be. That would mean that that chip is bad wouldnt it?:huh:
