I’m upgrading my 9 year old Hsu 1220 cylinder subs. I will be doing dual 20” sonotubes with about 60” in tube length. Sonosub.exe shows this will result in about 9.85 cubic foot (272 liters) size. I will initially use Hsu’s combination amp/x-over to run the subs.
Winisd shows the Q for a sealed option to be about .7 and but ported model doesn’t give a Q.
My HT/TV/listening room is about 3344 square feet, but there is a 5’7” opening into another 4000 square foot room. There is a 3 ½ foot hallway also leading off the HT/TV/listening room. Finally, one wall of the HT/TV/listening room is a 6 foot glass slider.
I do about 90% music and 10% movies. The current 1220’s have no mid bass weight or slam which is especially noticeable on movies.
I don’t use a receiver. I use a tube pre-amp and solid state amp. Speakers are full range.
I am leaning toward the 15” Tempest driver. I have ruled out the Dayton sub. I’ve looked at the Soundsplinter line up, but their website doesn’t inspire me and I have found little information from users on them. This may be because of the price difference compared to the Tempest.
Is there another driver I should be looking at?
Will the 15” Tempest do well in a ported design? Winisd suggests its best used in a sealed box.
