1 - 7 of 7 Posts
Hey guys,
I have a Sony mini Hi-Fi system. The model is MHC-GX99. The sub-woofer hits the <55Hz notes very quietly. I want to know if I can get any active sub-woofer to work with my system. Are there any key elements I need to be keeping in mind like the impedance, and sensitivity?
I don't have any idea how sensitive my subwoofer is at the moment, so I lack a starting point, but I do know it runs at a 6 ohm impedance. Any ideas are greatly appreciated!
Hello,
Adding a subwoofer to a HTIB is usually a very difficult thing to do unfortunately. If your Sony has an RCA Subwoofer Out, you are good to go. However, most Minisystems do not offer them. I am not familiar with your Sony, but will try to find out more about it.
Cheers,
JJ
Looked up the manual and it does have a Sub output so it shouldn't be an issue.
Hello,
Ares, excellent research amigo. That is great news as it opens up a World of possibilities for Subwoofer choice.
If not wanting to spend very much, Dayton's Sub 120 is available for around 150 Dollars from Amazon.
Cheers,
JJ
The subwoofer you offered looks nice, however that particular one does not ship to Canada. I found a good seller on ebay that offers full refund on all products sold. I'm just wondering which specs I should be looking for...because I don't have much chance to actually test out the speakers for myself.
Does the impedance have to match the 6 ohms that my receiver dishes out?
HD Powered Subwoofer 12" Home Theater Bass New TSRT500 --> ebay
Does this sub compare to the one you send me?
Hello again,
I got the subwoofer on ebay, and it's hits those low notes nicely...however, only after some massive EQ.
I have the sub connected to an external usb sound card, and I use a parametric eq for winamp. Below 32 hz, the volume is set at +5 db, while the volume around 60hz is at -13db.
Everything seems to be working great, but I am a bit worried about if the subwoofer is distorting. Isn't it hard to tell distortion at such low frequencies? I don't want to be damaging the subwoofer, so maybe I can run a distortion test on REW. Should I not worry about distortion and let the fuse protect me?
I'm confused...Help is greatly appreciated!!!
Hello,
If you are hearing a great deal of distortion, I would lower the levels. A fuse will more than likely not prevent a blown woofer.
Cheers,
JJ
1 - 7 of 7 Posts
