21 - 29 of 29 Posts
Discussion Starter #21
The biggest, but the biggest should always reach 100% or 0 dB if the impulse graph controls are set to normalise to the peak.
Thanks John
It seems to be sometimes a smaller negative peak then a larger negative peak is this normal?
I have looked back on other measurements and sometimes the biggest peak has gone from negative to positive with absolutely nothing changing other than possibly mics or postioing. Im confused why this could happen
I'm I doing something wrong?
Thanks again
REW Author
Yes
The overall sum of signals varies with position.
Probably not.
Discussion Starter #23
Hi John thank you
Even with small mic positioning it change from a peak to a negative?
I am trying to see if my centre is out of phase. This is a negative
Thank you
Discussion Starter #25
Hi John I have checked the polarity and it is connected correctly but the graphs shows incorrect polarity.
I have swapped the wires and polarity is good now, according to the graphs
Is it common that the internal wiring has been incorrectly wired?
Sorry at the moment I cant post files
Thanks again
Discussion Starter #26
Hi John to setup up the timing acoustic do I leave all the measurements with Acoustic Timing selected?
Thanks
21 - 29 of 29 Posts
