1 - 4 of 4 Posts
(1) The question is not will the mic work with REW , but " will the mic work with your computer ? " .
- I would assume the AntiMode mic requires some DC voltage ( phantom power ) to power up the capsule .
- Does your computer's mic input provide any dc power ? ( plug a 3.5mm to 3.5mm cable into the input and use a multimeter to look for DC voltage between the sleeve & either the tip or ring )
- Have you plugged the mic in yet to see if you can pick up any signal ?
(2) Most likely a working AntiMode mic is more accurate than the mentioned SLM .
:sn:
1 - 4 of 4 Posts
