1 - 2 of 2 Posts
Pardon me if this is a dumb question, but can I use REW to measure the difference between two condenser mics that have 2 rings mini headphone jacks? I know it won't be anywhere near "accurate". I basically want to verify that they are "equal" in response. As crazy as the response curves might be, I just want to see if they match one another. Does that make sense? Thanks!!
Yes, but you will need to be very precise in placement so each mic is in exactly the same place when the measurement is made. Probably best making the measurement close to the source and away from walls.
1 - 2 of 2 Posts
