1 - 9 of 9 Posts
Iv'e got REW up and running and am using it to measure and create FRD and zma files for crossover design. I have calibrated my EMM-6 mic and Audiobox twoi soundcard/analog interface and have started generating some SPL graphs with the mic 1M in front of the speaker baffle. How do I calibrate the absolute SPL db levels in my graphs? IOW, how do I get an accurate sensitivity level of my drivers (SPL output at a reference power level such as 2.83 volts)?
Thanks,
George
Thanks John. Can you point me to where I can learn how to integrate my SPL reading with the software to get accurate absolute SPL levels?
Thanks,
George
Thank you . After I calibrate my absolute SPL level with an SPL meter do I calibrate again at any time during a multi driver measurement session. Example: woofer alone in enclosure and then tweeter alone in same enclosure, then a different speaker in the same set up. Or do I only calibrate every time I change the set up, say on a different day?
Thanks,
George
When using REW to measure driver impedance is this best done in the enclosure if available or in open air?
Also, when measuring frequency response in the enclosure in preparation for crossover design is it best to use an empty cabinet or have it filled with the target level of stuffing/foam?
Thanks,
George
If you are measuring impedance to determine driver parameters then options are free air and added mass or free air and sealed cabinet.
For frequency response in cabinet I'd be inclined to measure with damping material, but you'll probably get more informed answers in the DIY Speakers or DIY Subwoofers parts of the forum :)
1 - 9 of 9 Posts
