1 - 20 of 68 Posts
You know that looks simple enough that I think I could even do it! :T
It is indeed pretty simple.
The only caution I can think of that might cause a hiccup is to make sure you don't have anything else open that might use HDMI, such as JRiver or another program that uses HDMI out. I had JRiver open and pulled up REW to test it out and could not get any output, until I closed JRiver, which I have setup to use HDMI.
It's fairly rare ( though more common on older PCs ), but not every HDMI equipped PC is able to output multi-channel sound through the HDMI connector .
One quick way to determine if the card ( graphics card actually ) will output more than 2 channels is to hover the mouse pointer over the appropriate output description ( as found within the ASIO4ALL control panel ) .
:sn:
Sometimes that is an issue with the multi-channel capabilities being disabled in the BIOS. Don't abandon hope till you rule that out.
Discussion Starter #8
Very good points guys... good information to have for verification and/or troubleshooting. :T
I'm PC illiterate how do you find out if the BIOS disabled the multi-channel and if the BIOS disabled the multi-channel capability what then ? is there a way to re-instate it ? I have a 2014 ASUS laptop with i7 and a realtek High definition audio with HDMI and I only see 2 channels ,also when I do a level test with HDMI out to the front HDMI input of my Onkyo 5507 I can see REW on the TV but the sound only comes out of my laptop speakers and not through my HT system. I've don everything in the link that you provided but I still have these two problems. please help but like I said I'm very PC illiterate
Based only on the i7 reference I found this. It may be it.
http://dlcdnet.asus.com/pub/ASUS/nb/X551MA/0409_E8619_A.pdf
Read through the section starting on page 76 "The Power On Self Test (POST)" COMPLETELY, first. You need to understand this.
If this looks right (and only if it looks right) you'll need to do the following:
*! Warning: Messing Around With The BIOS Aimlessly Can Render Your Computer Useless !*
If, during the following process, anything looks off press "ESC" to exit.
During POST press "F2" to enter the Bios Management.
Use the right/left arrow keys to highlight "Security" Press Enter.
Arrow key down to highlight "I/O Security" Press Enter.
If HD AUDIO Security is showing "Lock" then you need to proceed. If "Unlock" then this is NOT the problem. Press "ESC" until you exit BIOS. Look elsewhere for an answer.
I Locked then ...
Arrow key down to highlight "HD AUDIO Security" Press Enter.
Arrow key up/down to highlight "Unlock"
Press "F10" and follow the instructions to Save and Exit.
Good Luck.
Great info guys. Since winning the UMIK-1 last month I've only played around with REW once and did not have luck getting the multi channel audio to work. I'm hooked up through HDMI from my desktop to my AVR and it lists it properly but I'm not achieving the multi channel audio even when it displays it in the control panel for asio4all and in my computers soundcard control panel. I'll have to trouble shoot it a bit better I suppose
flamingeye said:
<<<<SNIP>>>>I'm PC illiterate how do you find out if the BIOS disabled the multi-channel and if the BIOS disabled the multi-channel capability what then ? is there a way to re-instate it ? I have a 2014 ASUS laptop with i7 and a realtek High definition audio with HDMI and I only see 2 channels ,<<<<SNIP>>>>
In your case ( with a new 2014 laptop still under a warranty ) I would seek help from the people who sold you the computer .
Telling them that you can't get multichannel audio to work for you ( & that's why you bought it ), should pique their interest .
:sn:
I will! I do not want to mess around with this laptop till I have a tech on the phone seeing that I have no tech skills with PCs and this is new anyways
Thanks for posting this link. Trying to search all the posts here and other forums makes it look more difficult than it is-at least to get the basics down.
This will make getting started on REW much easier and less intimidating!
Very basic question, does it make a difference between a camera tri-pod or an inexpensive boom mic stand for the Umik-1? Which might be better for proper placement and will either interfere with the results? If boom mic stand is better, any suggestions?
Easy to follow steps. Also found an You Tube video that walks the use through setting up a sub-woofer's room equalization using an SPL meter and REW. Very good as well.
why did I not find this when I was doing my testing this weekend lol...
I would SO love to do this so I can finally get an idea of how my system looks with Audyssey engaged and also see how my speakers look at my main LP individually rather than summed...
1 - 20 of 68 Posts
