Apologies for the big info dump, hoping it might provide a clue... Will hook up a proper setup later on to see what happens...
Thanks, Steve has generated an updated version with the bookmarks and it is now on the REW website.One thing I did notice, not with REW itself, but with the latest PDF help file, is that the bookmarks seem to have gone missing, so the tree view in the left pane of the Adobe Reader that one would normally use for quick navigation through the document is now empty.
Try 5.12.Ah well, overjoyed too soon. Gave it a quick try, and found numerous problems.
Cool! Thanks a lot!Thanks, Steve has generated an updated version with the bookmarks and it is now on the REW website.
Hello John,Try 5.12.
I had a lot of problems in the start up with the ASIO driver with the inputs/outputs but was easily fixed with some efforts on my part, since then it has been functioning properly without incident. I think this is contributed to the fact that ASIO is not the default audio device for the laptop. Either way I will try the new version and if not satisfied I can always switch back, thanks John.It's generally worth updating to the latest version, but of course not compulsory. 5.11 can have startup problems when using ASIO inputs/outputs, especially if the device(s) being used are also the default audio devices for the computer, but otherwise the changes are fairly minor.
There isn't a way to separate the contributions of input and output in a loopback measurement, but generally speaking the roll-off is predominantly in the input (provided the output isn't driving a load impedance much lower than it is rated for).I understand that with the USB mic you would not be using the same input as when you calibrated using the loop but what about calibration for the soundcards output while using analog RCA outputs?
YesI'm guessing if using HDMI the digital signal is perfect, is that correct?
No.Should I be calibrating the soundcard when using the RCA analog outs and the USB mic?
REW runs on Java, so the question boils down to will Java run on Windows 10, which is a yes. I haven't tried it though.Will REW run on Windows 10?
I need it on spectrum-mode though as lightning has stuff all the way to <2hzBTH, isn't that already on there?
http://img1.imagehousing.com/46/12d27e4ad35435e278ae1c93b27c7967.png
It's on my todo list for the Spectrum view. Not desperately difficult, but a bit greedy on memory and processing for the Spectrum view since there are FFT length points to compare and update every screen refresh, whereas the RTA has far, far fewer.Would it be really difficult to implement a peak-hold function for the RTA screen?
