1 - 5 of 5 Posts
I have a saved measurement in which the Filtered IR frequency selection drop-down is greyed out, locked in a certain setting.
Also, just loading that file starts keeping the CPU busy.
The fix I found is to uncheck and recheck Zero Phase Filtering (in Filtered IR's Controls).
Is this a known problem?
It opened without any problems for me, both with 5.18 and the latest 5.18 beta 3 version, the filter selection was available to change. You appear to be running quite an old version of Java, 1.7u51, though I wouldn't expect that to have any particular bearing on things. You could try installing the REW version with JRE to have a more recent Java runtime though.
Thanks.
I'll try newer Java. I think the REW+JRE installer got stuck for me, but I'll have another look or upgrade the global JRE.
1 - 5 of 5 Posts
