Picked up this old Velodyne DLS-3500R a while ago missing it's remote. The remote sets Phase, light, night mode volume and 4 presets for Movies, R&B - Rock, Jazz or Games. Any idea what the default preset is? The rest can all be set by the controls on back or by the receiver using the LFE input.
I'm tempted to replace the Plate amp which is 160 Watts RMS into an 8" 8 ohm driver. The box is ported thru a front slot.
Current frequency response is rated at 35 Hz to 140 Hz.
Parts express has several plate amps. The Dayton SPA250 is a direct fit and at 250 Amps into 4 ohms should work at 150 Watts into 8 ohms. Any ideas?
Any better amp choices?
The goal is to use the sub as a second sub in the rear.
