"Beating" is not an audio term. Can you be more specific? Do you mean HUMming? If so, you have a ground loop causing the humming. Connect the subwoofer to the same electric outlet as the amplifier... even if you have to use a power cord extension. If your voltage at home is 240 VAC, any extension cord will be OK. If your home has 120 VAC power, be sure the extension cord you use has 12 gauge or 14 gauge wire. A ground loop means that there is some voltage applied to ground... not a lot, probably only 2 or 4 volts. But that is enough to cause the subwoofer to hum with 50Hz or 60Hz hum depending on the power you have at home.
