1 - 4 of 4 Posts
Hello
I have problem with a sms1 it loose some times the lfe signal from Denon 3806 only when a use radio or tv not on cd or dvd player then the sms1 connected to a pa amplifier
Do i need to incrase the signal from Denon 3806 to sms1 or to the amplifier.
And what is the volt out of the sms1.
// Hakan
· Super Moderator
I can’t see anything in the SMS-1 manual that shows it automatically turns on or off with the presence is a signal, so yours may be defective.
The SMS-1 is a unity gain device, so the output voltage is same as the voltage from the input signal, ± the overall gain from any filters.
Tanks Wayne
Then i can use a samson s.convert to increse the signal from Denon 3806 to the amplifier if the signal only passing tru the sms1 .
1 - 4 of 4 Posts
