1 - 7 of 7 Posts
My velodyne spl12 finally gave it up. it has been a good sub with good output but the driver went out. the 750 watt plate amp is still working fine. Anyway it is around 300.00 to replace the driver and i was wondering if there is another better driver out there optimized for a smaller enclosure that is 4ohm?
thank you
If you like to play with stuff you could watch craigslist in your area for used 12" subs. You can pick up all sorts of 12" woofers for around $50. I know that car audio subs are not optimal for home audio but it could be much cheaper. I am not sure you would be able to tell the difference if you found a quality used car audio woofer.
1 - 7 of 7 Posts
