1 - 7 of 7 Posts
hi
i have just setup a roger sound labs 5.2 speaker package and two cg4s connected to a denon x6200w the two main fronts and centre connected to a xpa3 amp i will probably be adding roger sound labs c34e in ceiling speakers using blue jeans cables with a panasonic ub900 4k player
my question is i want to add a very high quality cd player to the above setup i want it to sound amazing what do people reccommend thanks
I would take a look at the Oppo 105...great sound and not over priced.
Be aware that if your going to connect the CD player using optical/coax (digital output) there really is no real sound difference between a $100 CD player and a $1500 one other then build quality.
Where the higher end players shine is if you run analog and use the players built in DACs .
The Oppo is a good choice.
I agree... with both comments. You need analog outs... OPPO 105 is one avenue (or waiting for the new OPPO 205 is another).
You can't go wrong with OPPO.
1 - 7 of 7 Posts
