1 - 5 of 5 Posts
Good morning
hope you can help me out for a moment here
I built a micro marty box that i outfitted with a TC Sounds LMR-R15 driver that i had.
here how i connected everything :
from Anthem MRX300 sub out rca to inputt1 of minidsp 2 X 4 balanced with cutout end connected to positive and shield with a small wire jumping the shield and negative input
Mini dsp output ( positive, negative, shield) to xlr input of ep4000
speakon connection output 1 (rewire for bridge mode ) to speakon input of micro marty
i am using 2 way advanced 2.1 plugin which i configured with lpf bypass and hpf to 23hz butterworth 12db
upon testing sub level out is very weak measured at 64 db with radio shack meter.
I removed the mini dsp and connected a rca to xlr cable directly to anthem sub out to ep4000 , i was no getting any sound
i tried the same thing with a rca to 1/4 plug sub level output was reaching 76db
Tried same test with a QSC rmx850 same result
So i am basically pulling the few remaining hair i have on my head trying to figure out what is wrong
Please help
Alain
Is 76 dB good or bad?
I don't know guess it is ......., at 64 it was not but i found the problem. The jumper inside the minidsp unit was set to 2 vrsm i moved it to 0.9 and it solved the low output problem
Gain structure is such a mystery
Alain
1 - 5 of 5 Posts
