1 - 5 of 5 Posts
When i try to hook my PC up to my TV through the VGA input i get a blue screen saying "WARNING: Turn on screensaver, refer to tv owners manual." Any ideas as to why this is not working? I searched the owners's manual and didn't find anything useful. Thanks.
Plain ole user
What resolution are you feeding it.? IIRC, it won't do anything over 650x480.
Thank you for your response and help.
My computer doesn't put out anything less than a 600x800 resolution. Any ideas on how to get the TV to accept that resolution through the VGA?
Plain ole user
If its upper limit is not that high the only way is to get a converter that does whatever the set will take. You need to find a spec sheet on the set to know for sure.
1 - 5 of 5 Posts
