1 - 4 of 4 Posts
Currently running a XFX HD-645X-ZQH2 Radeon HD 6450 1GB 64-bit DDR3 PCI Express 2.1 x16 HDCP Ready Low Profile Ready Video Card. Want to run MadVR at higher settings.
So the card is too tall for my case as I tried it. I have this case - http://www.newegg.com/Product/Product.aspx?Item=N82E16811204030
Card is 4.61" according to website.
Case says 5.4"....
I would have to remeasure but guessing 1/2" too tall.
Is there another comparable card that might fit in this case? I think it can't be taller than 4". Looking for something comparable to the one I had bought.
I recently came across this one. http://www.newegg.com/Product/Product.aspx?Item=N82E16814202012
Without having your case in my presence, i can only take educated guesses. From the photographs on newegg's website, it appears to be a standard sized chassis and the video card appears to use a standard peripheral slot and it is not a full sized PCI card.
If I were looking to assemble a system using that chasis, I would'nt have any issue using the video card you are asking about.
I believe those measurements listed are top to bottom outside of case as it isn't inside case. top cover would not slide back on.
1 - 4 of 4 Posts
