1 - 5 of 5 Posts
You might try a few more attempts at the soundcard cal routine to try and eliminate the oscillation at the upper end. Try some different sweep levels between -12dB and -6dB to see if you can clear it up....
Ultimately I really don't care about the upper end response, I mainly want this for subwoofer response and integration...
How does it look as far as that goes...
It's good for that.... only the upper end of the cal file is suspect...
Thanks Bruce, though down the line I would like to get on top of this...
Feelin a bit retarded with REW so far.... just haven't gotten the hang of it yet....
I'm running a New Dell Latitude E6500... It doesn't seem to have all the tweakable settings for audio with this version of vista business, a bit frustrated with the lack of audio control here....
1 - 5 of 5 Posts
