1 - 3 of 3 Posts
I have a Sony dh740 av receiver and a lg blue ray player (not sure of the model) when ever I adjust the volume on the receiver while I'm watching a blue ray disc it will restart the movie, it does it if I adjust the volume by remote control or the knob on the receiver.
Hdmi runs from the br player to the av receiver then on to the TV. I know it has to be some kind of control over hdmi, any suggestions on where to start looking?
Are you using BRAVIA Sync? try turning that off in both the receiver and the Bluray player
If the Bravia sync is not the problem...is this a new problem with an established system or a new system that you are trying to make work correctly ?
1 - 3 of 3 Posts
