1 - 3 of 3 Posts
With that being the case, I think I would personally opt for the VTF-15H. You might have to dial it back a bit for the short term, but you won't feel the need to replace it later when you go to a bigger space.
27dnast is actually somewhat in this position. He has a MK4 right now and is trying to decide if he should go with 2 MK4s or one 15H. He contacted HSU and they suggested that going with the one 15H would be the better of the 2 options. With that being the case, even if you decided to add a second later, it still might not equal one 15H.......
27dnast might be able to provide a little assistance - and I am pretty certain he has lauded HSU's customer service so you might be able to contact them directly. IIRC, there are a couple other owners as well that may be able to help (names escape atm unfortunately).
I own 2 SVS subs, so I am probably not going to be much help setting it up. :(
1 - 3 of 3 Posts
