I'm planning on rearranging my space. I'm using polk monitor 40's for side surrounds and stands. Where I'd like to move them, I can't use the stands I think they pretty much need to be wall mounted.
Anyone know if there are wall mounts for speakers like this? The are pretty fairly large bookshelf speakers.
Currently I using the Pinpoint AM40 for my rear speakers which are PSB B15's, I have had no issues with these mounts.
Just adding another vote of support for the Pinpoint AM40 mounts. I use them for a pair of Paradigm Mini Monitors. You could add a little bit of blu-tak/museum putty/reusable adheasive/etc to stick the speakers to the mount nicely. I did just that. They do come with little mounting screws if you don't mind drilling some tiny holes in your speakers.
Thanks folks. The Pinpoint AM40's look like they will be exactly what I need.
Sorry for not mounting the spec's. I have them, I just didn't think to post them.
